I've got to remove the laser assy' so as to clean them. faint black copies after PM still. I've taken the by-pass assy off and other panels and frame piece. I've got the end all clear for this laser box to pull out. It will not. There must be something on the fuser door side of the machine still holding it in place (springs?) or something... I can jostle it around a little but there is something still holding it in place. Any help would be greatly appreciated. I don't have the disassembly section in my manual...TIA -Steve
Removal of laser unit Taskalpha 300i
Re: Removal of laser unit Taskalpha 300i
If you have got as far as to removal of the lsu cover then, the rest is as follows.
13. Remove two screws and remove the cooling
fan assembly
14. Remove three screws and remove the LSU
cover
15. Remove two connectors.
16. Remove four screws and remove the laser
scanner unit.
17. Replace the laser scanner unit and install
the unit.
18. Refit all the removed parts.
nothing else to hold it in place.THE ONLY THING FOR EVIL TO TRIUMPH IS FOR GOOD MEN TO DO NOTHING..........edmund burke -
Jammed,
If you are working on a 300ci instead of a 300i black and white, then yes, there are two retaining screws and springs that must be removed from the registration area below the fuser. There are two small access holes through the black plastic guide; they are MUCH easier to see and remove with the left side conveying door removed. In fact, they are nearly impossible to remove without first removing the left side conveying door assembly.
Oh, have fun!!Comment
Jammed,
Oh, have fun!!
I responded to the model he quoted in my earlier reply to this post.THE ONLY THING FOR EVIL TO TRIUMPH IS FOR GOOD MEN TO DO NOTHING..........edmund burkeComment
