TaskAlpha 300ci
  • cpcp25
    • May 2025
    TaskAlpha 300ci
    all toner levels are low showing 55,51,16,23. Run code 132 with the toner bottle out and the lower auger does not turn. So not adding toner, any help would be more than appreciated
  • Tonerkiller
    • Oct 2012
    • 665
    Re: TaskAlpha 300ci
    Start from the beginning. What problem are you having with the machine?
    • cpcp25
      Re: TaskAlpha 300ci
      Error codes 7101 to 7104 thanks they are using oem toners.
      • Ropariva
        • 639
        Re: TaskAlpha 300ci
        Sounds like the K dev motor isn't running. I have a note in my manual for 7101 to check dev motor. 7104 or related to the same thing but on the yellow dev.
        • Tonerkiller
          • Oct 2012
          • 665
          Re: TaskAlpha 300ci
          All 4 codes? Sounds like a pinched wire.
          • Reed
            • Feb 2011
            • 256
            Re: TaskAlpha 300ci
            I had the same problem a while back. Had to replace a couple motors. Kyocera has a tech bulletin concerning this problem. I can send it to you if you would like
