KYOCERA FS-1028MFP
  • zaza
    MECANOGRAPHE
    • Mar 2008
    • 1095
    [Misc] KYOCERA FS-1028MFP
    hello all my tech friends ...we have fs-1028mfp ...if we started copy all copy is white any copy ...good drum ..good toner pls any idea to sloved my problems
    BEST TECHNICIAN . NICE PEOPLE .
  • acusso1234
    Tecnico
    • Dec 2008
    • 250
    Re: KYOCERA FS-1028MFP
    Is your toner cartridge properly installed?
    Can you see toner on the magnetic roller of the developing unit?
    Try running sim 130
    ... In the minute that you're thinking of giving up, think about why you lasted so long ...
    • Tonerkiller
      • Oct 2012
      • 668
      The drum unit is not seated properly.
      • copier parts n.ireland
        • Nov 2016
        • 41
        had this a few times,can be the lsu shutter guard is sticking hence laser is not putting image on drum ,removing and refiiting drum cures,had a few springs off after removing side cover as well
        • kyogenius
          • Jul 2012
          • 136
          very true have encountered this problem on so many machines
          failure is not an option !
