Kyocera km-c3232 dv problem
  • dustzona
    • Mar 2015
    • 83
    Had a black DV unit lock up and strip the gears. I replaced the unit and it worked for about an hour before customer called and said its asking for toner again.
    Is there a calibration for the DV unit ?
    • 22999
    Re: Kyocera km-c3232 dv problem
    The machine does the developer stir itself automatically. The problem is that when the developing unit seizes, it also destroys the black developing drive clutch. It's reasonably easy to get to from the rear, behind a black plastic cup (clutch part #: 302JD93123). Be sure to check the bronze bushings and the plastic housing that the bushing set in at both ends. The bushings can oval out, and chew up the plastic housing, or heat up and melt the housing. In either case you'll need the main drive assembly instead. Be sure to check before ordering parts.
    You will still need to do a color calibration when you're done. =^..^=
