Will not fax automatic, changed setting to memory transmission, will scan documents and just sit there, does not dial number, but if you insert documents and hit on hook, dial number with documents in feeder it will scan and dial number and send fax. Other wise it will not send fax. Not familiar with this machine fax procedures. Any suggestions? Thanks.
Kyocera fs 1135 faxing problem
Re: Kyocera fs 1135 faxing problem
Are you on a PBx? If yes, look in sim U660 for an option to select PBx settings. =^..^=If you'd like a serious answer to your request:
