Event log P2135
  • peteri
    • Jan 2012
    • 4
    [Jamming] Event log P2135
    how to see event log the Kyocera P2135?
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1869
    Re: Event log P2135
    !R! KCFG"ELOG"; EXIT;
    Type this into a text document & send it to the printers LP1 on the FTP of the printers IP address.
    Example FTP://192.168.1.200/
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • lees
      • Apr 2011
      • 95
      Re: Event log P2135
      You can put this in a folder on a thumb drive and print it from there. It will print a status page, service status page, and event log. It must be in a folder for it to work or the printer will not recognize it. You can remove stat (status page) and stat1 (service status page) if you only want an elog (event log). This is the simplest way to do it. Works on any printer or MFP that has the capabilities of printing from a thumb drive. Hope this helps.
      !R!ELOG;STAT;STAT1;PAGE;EXIT;
      • tmaged
        • Oct 2008
        • 1869
        Re: Event log P2135
        I need some more info Lees. I've saved it as a text document & put it in a folder, but can't get it to work.
        Am I missing something ?
        Hope that helps !
        -Tony
        www.dtios.com
        • Kyo fan
          • Dec 2013
          • 368
          Re: Event log P2135
          Just type http://IPaddress/eventlog in any browser and you will see it.
          • lees
            • Apr 2011
            • 95
            Re: Event log P2135
            Copy this !R!ELOG;STAT;STAT1;PAGE;EXIT; into a Note pad document, put it into a folder named what ever you desire. Save this folder to a thumb drive. Install thumb drive in printer and tell it to print the file. If you use Word type it in prescribe font. The capital letters are important as well as spaces
            • peteri
              • Jan 2012
              • 4
              Re: Event log P2135
              !R! KCFG"ELOG"; EXIT; - create text file in large letters
              FTP:// ip address from command prompt
              without "user and pass"
              put"file name"( location file )
              print event log page
              thank you all
              all the best
              • peteri
                • Jan 2012
                • 4
                Re: Event log P2135
                Ok!This works
                • subaro
                  • Oct 2010
                  • 1274
                  Re: Event log P2135
                  yes, it's the easiest way providing it has the optional nic card installed. standard is usb
