No paper tray selection on main copy screen.No duplex from main glass
  • bollard
    • Nov 2012
    • 40
    [Misc] No paper tray selection on main copy screen.No duplex from main glass
    Kyocera taskalfa 4501i.
    Missing paper tray selection box altogether ?
    No duplexing from main scan glass either ?
    Reset 024 , firmware downgraded/upgraded,reset 906. All to no avail...
    Anyone come across this issue ?
  • jmaister
    certified scrub
    • Aug 2010
    • 755
    Re: No paper tray selection on main copy screen.No duplex from main glass
    is it still 6 box, or only 5?
    Idling colour developers are not healthy developers.
    • Ctl-Alt-Del
      • Jul 2006
      • 430
      It sounds like you need to run a 906 but you already did that so I would make sure you executed that correctly. What happens if you unplug the accessories? Maybe backup everything to USB and try a U021.
        • 23010
        I would start by printing off the error log, so you can see what actual codes that you are dealing with. Then I would spend some time tracking down why the tray motors don't lift. =^..^=
        • bollard
          • Nov 2012
          • 40
          All paper tray motors are fine and all trays feed .
          All resets done no paper tray icon shown still .
          Still no duplexing from main sub glass .
          no event errors to refer to .
            • 23010
            Have you checked the power supply outputs? =^..^=
            • subaro
              • Oct 2010
              • 1274
              check below in service mode
              U343
              Switching between duplex/simplex copy mode
              Description
              Switches the initial setting between duplex and simplex copy.
              Purpose
              To be set according to frequency of use: set to the more frequently used mode
              On Duplex copy
              Off Simplex copy
              • mita
                • Sep 2010
                • 87
                It is possible that the HDD is having problems as all the extended functions work with that.
