DP-770 with J9000 jams
    • 23010
    I swapped the paper present sensor with another to confirm that the sensor was OK. The key, for me, was that when one original was inserted and fed, the DP continued to attempt pickup, even though the one original had already completely exited. And when you re-installed the same one original, I insisted that it wanted more originals.
    Another forum post confirmed for me that it was something to do with the paper present sensor, but what?
    While I was watching the paper present flag I noticed that it bounced when the flag dropped. So the DP controller saw the signal go from On to Off/On/Off. The flag is only gravity operated, so I added a very very weak torsion spring to damp that bounce. To make sure that the spring tail didn't move around I carved a small groove in the frame and gave it a dab of Lazerbond (my new favorite glue). A counterweight may have served the same purpose.
    Afterwards I made 30 separate scans without the J9000.
    In that forum post tmaged refers to adding a black tape extension to the flag. I think that helps because the tape adds counterweight to damp the bounce also. I think the sensor flag is long enough, just shouldn't bounce. =^..^=
  • Has Been
    • Nov 2012
    • 48
    Re: DP-770 with J9000 jams
    [ATTACH=CONFIG]32905[/ATTACH][ATTACH=CONFIG]32906[/ATTACH]
    Has the small tab on front of the roller holder been broken off ?
      • 23010
      No, I checked for that. =^..^=
      • subaro
        • Oct 2010
        • 1274
        You were right on track there blackcat. see the bulletin. the cut off is shaving off the middle of the actuator in a C type manner OR just making a curve on the original actuator.
        There is a bulletin for this jam on the dp-770
        QA E187
        Due to the parts variation, the original detection SW actuator may come in contact with the original lift plate and
        vibrate after the final original is fed. When it occurs, the light interruption time of the original detection switch
        becomes shorter and the J9000 (No original feed JAM) may be detected. As a preventative measure, the
        following change is implemented.
        [Change to the original detection SW actuator (No.1)](Old) (New)
        It is cut off here
        so it does not
        come in contact
        with the original
        lift plate
        • subaro
          • Oct 2010
          • 1274
          Here is the part number for the new actuator.
          303LL07281
            • 23010
            Thanks for the bulletin and part number subaro. =^..^=
