2 Brand new 9530's with PF-750 duplex jams
  • CPI
    • May 2016
    • 8
    2 Brand new 9530's with PF-750 duplex jams- All trays including PF-750 large capacity tray feed single side with no problems. Trays 1 and 2 duplex with no jamming. Tray 3 / PF750 jams when duplexing same place every time.
  • Kyo fan
    • Dec 2013
    • 368
    Re: 2 Brand new 9530's with PF-750 duplex jams
    What same place? what jam code?
    • Tonerkiller
      • Oct 2012
      • 665
      I would clean the two vert tran clutches. just like, I think it was a j21 on a km-420. Sometimes there is too much grease on them from the factory
      • CPI
        • May 2016
        • 8
        Jam code 61. Kyocera says also to replace conveyance clutch for possible too much grease on clutches from factory.
        Sent from my Z930L using Tapatalk
        • subaro
          • Oct 2010
          • 1273
          I agree with replacing those clutches, but they are electronic clutches and can't see how grease are used on them. The conveyance unit is different from the veritical unit. I would think as tonerkiller says its, the vertical transport unit clutches, and they are just plain faulty. check the parts list.
          • CPI
            • May 2016
            • 8
            We got 2 of these "302GR44120 CLUTCH FEED" ordered to replace on the VERTICAL FEED UNIT. Seems to be the only solution suggested so far.
            • Tonerkiller
              • Oct 2012
              • 665
              I have cleaned the vert clutches for this problem. There is a white grease on the clutch face so they do not rust in transport. I know that does not make sense, but I have seen it a few times
              • subaro
                • Oct 2010
                • 1273
                setup lots of these machines, but never seen the issue really. I don't print lots of pages on setup, just a couple to make sure all the feeder ect. work. Have heard about it from the guys in the field and all type of resolution have been mentioned inculding the vertical transport unit clutches. Here is the situation though. There are 5 more of the identical clutches on this machine, 1 on bypass, 2 conveyance, 2 drive section and the 2 on the verticall unit.
                • CPI
                  • May 2016
                  • 8
                  Replaced the 2 clutches on vertical transports of both machines.. They came with a smaller clutch than book shows/ different part number. Had 3.5w clutches and replaced with the correct ones that were 4w alot bigger clutches in size. No further jamming issues with either machine 15k prints since change of clutches.
