FS-2100DN not connecting to network.
  • DavePo
    • Jul 2008
    • 305
    Have a new FS-2100DN fresh out of box, when plugged into network doesn't show any network connection. Status page shows under current LAN interface not connected. Have tried different cables and ports in switch. Have updated firmware to 2lv_3f00.015.304. I am leaning towards bad main PWB. Has anyone else seen this? I am new to Kyocera line.
  • subaro
    • Oct 2010
    • 1274
    Re: FS-2100DN not connecting to network.
    Default is dchp on. when power on, you have to wait about two minutes before printing the status page ,then the ip address shows on the status page. Better set the ip adress to static and ping it from your computer. when any settings is made, power off and on again.
    • DavePo
      • Jul 2008
      • 305
      My issue is that i am not showing any link on the switch and status page shows no connection also. This is either dhcp or static.
      • subaro
        • Oct 2010
        • 1274
        Well the bullet proof method still stand by using the crossover cable to verify the nic is working on the machine. If you have another machine there, use the corssover cable and test it first and then test the 2100. It is possible the nic is bad. have setup hundreds of all type of kyocera and not seen a bad nic as yet, that is new out of box. With kyocera warranty, i would call them and let them recommend what to change, in this way your warranty claims are handled much faster.
        • NeoMatrix
          Senior Tech.
          • 3513
          Reboot the Link/Router, I've seen that a few times....
          As Subaro said "try to use a crossover cable" as a test.
          If you are not getting two lights on the NIC you have a problem with the cable. Check there is no bent pins in the Cat5 socket and the cable has a clean cat5 connector(RJ45) that has not been crashed or mutilated around the ends.
          I've seen a mutilated CAT5 end connector on a cable which had crashed plastic fins/guides laying over on their side preventing electrical contact inside the ethernet socket. When briefly looking at the connector it looked okay, only on closer inspection could I see the problem.
          It could be a rare case of DOA.
          • DavePo
            • Jul 2008
            • 305
            Neo your where on the ball. The problem was one of the pins in socket was bent. Another issue was that HTTP protocol was turned off. Straightened pin and enabled HTTP and all is good.
