Kyocera 3500 fax card
  • tech28
    • Jun 2013
    • 434
    Just wonerdering if the fax cards on these machines plug and play? Going from one machine with one to another one without.
  • darry1322
    • Oct 2010
    • 817
    Re: Kyocera 3500 fax card
    It can be moved just remember to move the fax card and the fax DIMM. When you turn on the copier you will get a C06XX code. Run DIMM memory clear to reset. When you go into Maint Mode after the code it will be the only Maint Mode you can access above MM600. I can't remember the exact MM number off the top of my head.
    • Has Been
      • Nov 2012
      • 48
      Sim 617. Card must be mounted in the new machine when doing this.
      • tech28
        • Jun 2013
        • 434
        Fax dimm on machine? If no dimm, no install I take it?
          • 22933
          One of the DIMMs on the Main PWB will be labelled "FAX". If you want your fax option to work, that
          DIMM has to go with the fax card, and the memory clear of course. =^..^=
          • subaro
            • Oct 2010
            • 1274
            The fax pwb can only be used on machines that support them, usually it's within a specific series. They cannot be used in any kyocera machine that supports an optional fax pwb. There are s type v type ect. Check the machine specification documents or kyocera Bulletin1 for the machine in question.
            • tech28
              • Jun 2013
              • 434
              Thank You guys for the information. Much appreciated.
