kyocera jam 4602 , the copies goes wrong way
  • cdvidaceiba
    • 80
    hi i got a Kyocera 8000i thats works fine for the right tray , but if i want to use the left trays the copies jams in the exit section , specificaly the copies goes for the duplex not for the exit ... i already tried everything
    thanks in advance for the help
  • ntbann
    • Jan 2012
    • 631
    Re: kyocera jam 4602 , the copies goes wrong way
    Check the transport sensor flags. They get wore off and cause the jam you listed.
    • cdvidaceiba
      • 80
      i suspect of the duplex flapper (guide change lower 302K928213) seems worn out , i dont have one for replacement i will try to modify this one
      i check the sensors but the machinne works fine if you program a copy duplex mode and right exit , the problem is only when you program left exit the copy doesnt go for the exit to the bridge unit , the copy goes for the duplex
      • cdvidaceiba
        • 80
        i solve the problem modified the whole unit , i had to displace the exit unit to the rear , the machinee work ok now
