toner 8000i same as 5500i (powder)
  • cdvidaceiba
    • 80
    hi i am located in Honduras and sometimes its pretty hard to get toner for Kyocera 8000i , my question is the following
    is the toner ( talking about the powder only) for Kyocera 5500i is the same as Kyocera 8000i ?????
    thanks in advance for your help
    • 23008
    Re: toner 8000i same as 5500i (powder)
    If I were to make an educated guess, based on the classroom materials, I would say your best candidate for a substitute is the KM-7550ci black toner TK-8707K: Kyocera TASKalfa 7550ci Black Toner Cartridge, Genuine (G1811)
    The classroom materials state that the developing process for the Zeus is a direct adaptation of the Mercury development system, both with the 40mm drum. The Gaia developing system is a further adaptation, but for the smaller 30mm drum. =^..^=
    • Alexkyocera
      • Jul 2015
      • 82
      I am a million percent SURE that its the same composites that makes up both toners, therefore it can be done cdvidaceiba from Honduras
