Which Kon.Min. feed rollers are preferred to use in 4550ci ?
  • CCS
    • 266
    I've read some have better yields using some of the Konica Minolta feed rollers in 4550ci, which model feed rollers work good in the 4550ci ?
    • 23008
    Re: Which Kon.Min. feed rollers are preferred to use in 4550ci ?
    quantity (2) A00J 5636 00
    quantity (1) A5C1 5622 00
    You'll have to use the original hubs on many models, but the rubber seems to be universal. This is what I use to press off the rubber:
    NeoMatrix has several fine ideas for roller presses.
    For the full thread: http://www.copytechnet.com/forums/ky...highlight=A5C1
    • CCS
      • 266
      Thanks blackcat, neat setup you got there, gives me some ideas.
      I usually just cut off with razor and put others on hub with soap water or spit.
      Your the man, even got the part #'s, thanks again.
        • 23008
        Thanks!
        For the sake of simplicity and convenience, I like this roller press the best. It's one of Neo's ideas. Start with a worn out (or new) stubby Phillips screwdriver. For comfort and ease of operation you'll want a minimally short handle that will fit nicely into your palm and the shaft cut to a short length, so you can use your fingers to hold the rubber.
        I've spent way too much time thinking about this and other projects. Another potential for a great universal tire remover (but not installer) is a standard hose removal tool. They may work fine as is, or maybe it might be beneficial to grind out the center of the "V" slot to a 9mm radius to accommodate the hub OD.
        The hard part of the tire swap seems to be getting the new rubber off the hub intact. We don't care so much what happens to the old rubber.
        I'll be interested in your thoughts on the subject. =^..^=
        • CCS
          • 266
          Oh yea, I forgot briefly about the most important part of getting the new rubber off of hub to use it, lol. That's where some tools or thinking will come in, I know that's a pain, I've used this or that but nothing that works really well and alot of time just tear tire up getting it off. I was thinking the swap in rollers you suggested fit hub and all, guess can't get that lucky. I'll post if I figure something good out.
          • Hansoon
            • Sep 2007
            • 3385
            I cut the old roller to get them off and use Windex to slip the new one on. That's it.
            Hans
            • subaro
              • Oct 2010
              • 1274
              Hans
              Ok Hans, you address the easy part. The above quote from blackcat needs your attention and reply. How do you get the new rubber off from the new minolta hub intact ?.
              • Hansoon
                • Sep 2007
                • 3385
                Well, I didn't realize that problem cause we are using after market tires without hub but I recall that in the past we used compressed air between the hub and the tire to get them off. Hard to explain how it works but it does. The air somehow expands the rubber and than its much easier to push the hub out.
                Hans
                • CCS
                  • 266
                  What supplier and part# for the aftermarket tire you are using that comes without hub ?
                  Are they any good, how much yield from them ?
                  • Hansoon
                    • Sep 2007
                    • 3385
                    We let them manufacture for our own purposes. Yield same as KonicaMinolta. Price USD 8.80/pc
                    Hans
                    • NeoMatrix
                      Senior Tech.
                      • 3513
                      Hans
                      Re: Compressed Air
                      I/we use the same compressed air expansion method to replace rubber sleeves on tool handles,splines and likewise children's wooden cricket bat handles. You have to form a seal at the point of air input and the rubber sleeve will expand and slide over the shaft with a cushion of air as a lubrication effect. The air compressor sleeve insertion method works very well; the compressor provides the largest volume and pressure of air flow required to do the job.
                      The problem though with feed tyre sleeves; you can't take the air compressor into the customers office.
                        • 23008
                        ... The problem though with feed tyre sleeves; you can't take the air compressor into the customers office.
                        Well you can ... but an air compressor is heavy, noisy, and you only need it for 10 seconds at a time. It hardly seems worth all the hauling, and space in the car, and the racket, and hooking up cords, ... all for 10 seconds of use.
                        The manual press works quite nicely for 1/2 dozen rollers. =^..^=
                        • subaro
                          • Oct 2010
                          • 1274
                          [ATTACH=CONFIG]33688[/ATTACH][ATTACH=CONFIG]33689[/ATTACH]
                          How difficult is it using that tool to remove the neoprene roller from the konica or kyocera hub ?. We only use oem rollers as the company pays for it. Once i wanted to use the neoprene Feed/sep rollers used on the kyocera LCT PF-750 and attempted to remove it from the hub. I huffed, puffed and banged and it was as hell to get off. Alcohol does not work to remove these as with rubber rollers and they does not seem to stretch a micrometer. So what is the easiest method to remove the neoprene rollers ?, as i want to use a few for a project.
                          And is it just as difficult to install in the hub. I used up huge joules in removing that roller, hoping for a much easier method.
                            • 23008
                            Originally posted by subaro
                            How difficult is it using that tool to remove the neoprene roller from the Konica or Kyocera hub?
                            It takes some hand strength to operate. With all modesty, perhaps I might have more hand strength than the average person. If you can get a drop or two of glass cleaner or water in between rubber and hub, it becomes easier. =^..^=
                            • subaro
                              • Oct 2010
                              • 1274
                              Thanks!
                              [ATTACH=CONFIG]33690[/ATTACH]
                              [ATTACH=CONFIG]33691[/ATTACH]
                              Here is my solution i thinkered with and found to work with ease for removing and installing. The tool is essentially an eyebolt with washers that is applicable. This can be modified or upgraded with some imagination.
                              The neoprene roller seen in the pics below could never be removed with hand strength, it's just too tight in that hub, no compress air or push assy would move that roller. The roller is from the kyocera pf-750 console.
                              The nut runs down the thread fast and tightening does not necessarily need a wrench, but if difficult an open end wrench to hold the nut can be used or better i saw a plastic wing type nut assy at the hardware that can be used. The bolt is 1/4 inch and cost 1.50 . This works fantastic and if i had to change rollers this is what i would be using with a little bit of modification. It can accomodate any size roller in width and most shaft are 1/4 inch or more, so most rollers can be used. enjoy and let me hear the feed backs.20160828_154703.jpg20160828_154211.jpg
                              The washer below the roller was to prevent the device from rolling off the table.
                              patent pending
                              One pic shows removal and the other installation. This would never damage the hub or roller and can be installed without using any liquid as lubricant, but using water or other installs better. when the install is done an plier should be used around the roller to even out the roundness so the surface is level end to end and not with a bulge, this is what i found anyway.
