Kyocera taskalfa 3050ci jam 0100
  • Azharuddin
    • Jun 2016
    • 33
    [Jamming] Kyocera taskalfa 3050ci jam 0100
    Hi
    Jamming every time whenever printing.
    Paper is on registration roller only. One engineer came and said problem with fuser we need to replace. What could be the problem with fuser .we can repair or not. Thanks in advance.
    Sent from my XT1562 using Tapatalk
  • subaro
    • Oct 2010
    • 1274
    Re: Kyocera taskalfa 3050ci jam 0100
    update the firmware. If still not fixed, format the hard drive and update firmware again. Don't ask for the firmware i, don't supply that item.
    0100
    Backup memory device
    error
    EEPROM(main
    PWB)
    1. Turn the main power swtch off and after
    5 seconds, then turn power on.
    2. Check that the EEPROM on the main
    circuit PWB is peroperly installed on the
    main circuit PWB and, if not, re-install it.
    3. Replace the main PWB
    • TECHKYO
      • Aug 2016
      • 15
      agreed with subaro but from my side I encounter same issue then I solved by replacing fuser unit
      • JVergin
        Service Tech / IT Rep
        • 216
        We had this code before. Tech support said it's not really a jam code, but rather an error code. This was on a 3051ci. Here's what we did. Have not had the problem since:
        REASON FOR SERVICE CALL
        J0100, J0110 intermittent, one C0800 code in log
        - reseated all board connections,
        HDD, Memory, fax and fax DIMM
        (Made problem 10x worse)
        - replaced MAIN PWB for false jams
        and locking up at reg roller
        • KYO_OEM
          • Aug 2011
          • 728
          • Azharuddin
            • Jun 2016
            • 33
            Thanks everyone,
            As I said before after jammed twice it's giving error code as 0800.
            • UKTeam
              • 24
              As already suggested, it is most likely your Fuser.
              I had this and kept this log...
              Symptom...
              Paper is fed to the registration roller successfully and is paused, as normal.
              The machine will then idle for around 40 seconds without further activity and then report a Jam. (J-0100 or 0110)
              (During the Idling time 'processing........job' scrolls at the bottom with the two green lights flashing as normal)
              When the Paper is removed and the Jam is released, this routine repeats.
              Upon clearing a third time the system error C-0800 is reported and recorded.
              C-0800 - Image processing trouble.
              That seems reasonable because it is the point at which Data should be compiled and sent to the LSU (before Paper registration resumes), that the machine becomes 'stuck' in this loop.
              However, Noisy/Erratic Thermistor outputs were the cause.
              Meaning that as the paper is presented at registration, the Main PCB waits for a stable FUSER temp reading before resuming with image formation.
              All FOUR Thermistors within the Fuser unit (3 Lower, 1 Upper) were swopped with second-hand spares, taken from a saved Fuser which another end user wrecked clearing a Jam!!!
              • giddyupngo
                • Oct 2014
                • 109
                THANKS, I had one with a consistent jam 0100 code/system error 0800, manual says EEPROM/MAIN Board, replace main board. I searched here and found this. Removed fuser, and cleaned out a bunch of black chunks from the fuser. I think the chunks probably stuck to one of the thermistors, causing this error. Put it back together and error did not come back. Did have a bad developer, which possibly caused the black chunks. Thank you!!!!
