Sorry for the previous post ending in print. I know better, just had a serious Friday brain fart.......So I have a Task Alfa 3500i that will not print at all. I can ping it, have the KX driver loaded but no test page. No blinking data lite, nothing. It did have Paper Port as an app but I deleted it so........
Task Alfa 3500i print issue
Tags: None
Re: Task Alfa 3500i print issue
Have you tried direct connecting or at the very least bypassing any switches, routers, or firewalls that may be affecting traffic to the copier?
edit: Just also considered that you may have an IP conflict. Unplug your CAT5 from the copier and ping again.Last edited by wragsdale; 08-12-2016, 08:31 PM. -
Unless you can get to the web page, you don't know what you're pinging. As Wragsdale said, unplug it then ping. If you can get to the web page, it's a port issue.Comment
Delete the current print driver and re-install it using the latest KX driver package. Upon re-installing, select using the printer name versus the IP address, this will eliminate any IP conflicts, which I believe you have. As Tony said, just pinging the IP address does not mean that you are getting to the machine it could be another computer on the network. Unless a DHCP reservation was made for the machine it could have received a new IP address, after a power failure DHCP will re-assign IP addresses and you could now be trying to print to a computer which of course will not work. Have you checked what the 3500i's ip address is from the machine's control panel and whether it is dynamic [DHCP] or static? Just a few things to check.Comment
Thanks all. No dual IP address on network. I'm just stupid. Found a bad Ethernet connector on the machine side. Made a new cable and it prints now. How I could ping it I have no idea unless the connector was faulty (loose connection).Comment
The ping command is very basic. There was enough of a physical connection to ping it, but not enough data was getting through to open the web page or make it print.Comment
