TASKAlfa 400Ci does not want to copy!
  • gtr-electro
    • Jul 2025
    [Misc] TASKAlfa 400Ci does not want to copy!
    Hello All,
    Im a french guy, First time I come to this forum, thanks for your energy and sympathy to help others!!!
    I bought this day a TaskAlfa 400Ci.
    After few repairs regarding the optical unit (C3300 error), which was only sliders on the optical mirrors that are broken (and AGC cannot work well)
    Right now, the copier is almost working but:
    - Scannnig OK ( previsualisation)
    - Printing OK with Status page, and from PC thru network
    - 4 Toners OK, Prints are quite good quality.
    But 3 things not normal:
    - I cannot be able to copy. (the display panel beeps 2 times at each button I click.)
    NOt able to copy, not able to send by email, not able to save in local....
    - Button Help is not working: I do not have any Help
    - Maintenance code is not working!!
    I tryed factory reset from UI, From Web interface without any success, more or less every tact switch on the display panel sound to me beep beep, and no copying action (can change parameters..)
    I woul like to know if this Printer can be locked?
    Do you have any Idea to unlock it?
    I cannot found results on this problem on the Internet....
    Thanks for your help!
  • Has Been
    • Nov 2012
    • 48
    Re: TASKAlfa 400Ci does not want to copy!
    Originally posted by gtr-electro
    Hello All,
    A key is stuck down or you have a bad operation panel. Some times disassembly and cleaning of the unit will help.
    • subaro
      • Oct 2010
      • 1274
      The previous reply may be the cause, but you can check the following below here.
      from your browser input the ip address of the machine and input default password admin00
      Basic > Security > Device Security > General
      This page allows you to restrict access from the operation panel or USB host device. In
      addition, an explanation about each security setting is displayed.
      Item Description
      Lock Operation
      Panel
      Restricts access from the operation panel. With some
      models, this setting is irrelevant if the user has logged in as
      the Administrator.
      When it is set to Lock (Block), use of the System menu on this
      machine, registration in and editing of the Address Book and
      Box, use of the Stop key, and cancellation of jobs are forbidden.
      When it is set to Partial Lock, use of the System menu on
      this machine and registration in and editing of the Address
      Book and Box are forbidden.
      When it is set to Unlock, use of all keys is permitted.
      service mode below
      U223 Operation panel lock Unlock*1
      • gtr-electro
        Hi, Thank you for both answers, I double check on the Keyboard, and it seems to be that....
        While pressing on the casing, I can avoid the bad contact and can make copies...
        So I will dissassemble, and clean the keyboard, and found the bad contact or shortcut on the keys...
        I will post the result...
        Best regards
        • gtr-electro
          Thanks for your help, the copier works well!
          The problem was the distance between plastics and tact switch in the keyboard, on certain key, it can be pushed every time...
          I put small washers and it is OK now.
          There is 0,5mm distance between tact switch and plastic buttons, and all is Fine!
          Every feature works now ( Maintenance code, Help etc..)
          A big thank for your help.
          Best regards
