KM5050 fuser in a 520i
  • copyaction
    • Oct 2007
    • 991
    I see different part numbers but I only had a 5050 fuser and installed it in a 520i and it works so far.
    anyone know if they are interchangeable?
  • Santander
    • May 2009
    • 768
    Re: KM5050 fuser in a 520i
    Many of the parts in the 5050 are the same as in the 420i/520i. If you dig down through the sub-parts list you will see that most are the same, most importantly the connection harnesses are the same. There are differences but a careful analysis will show many of the assemblies are interchangeable. In our case it is usually the reverse, putting 420i/520i parts in a 5050.
      • 23009
      I seem to recall getting a C6xxx when I tried this. I expect that it won't work. =^..^=
      • copyaction
        • Oct 2007
        • 991
        So far it is working I will keep an eye out for the code and swap it out if it pops up.
