Kyocera taskalfa 306,406 ci color tables
  • simonsays
    • Aug 2013
    • 95
    Anyone here working on the new taskalfa's 306 or 406ci using maint mode 485 setting color profiles have any of you altered the color profiles when customers colors aren't the color they are looking for
  • simonsays
    • Aug 2013
    • 95
    Re: Kyocera taskalfa 306,406 ci color tables
    WOW!! 54 views not 1 reply
      • 23009
      I have tried color tables on the VoyagerE and Saturn series on a couple of occasions, and was consistently disappointed with the results. It's not any kind of magical panacia in my experience. =^..^=
      • TECHKYO
        • Aug 2016
        • 15
        color tables in fact not that good result but from my side I would like to select type -TO
        one more thing some machine better not to use color table ( TA 2550 / TA 2551 )
        be aware once you select any type the profile will be there even if you uninstall the color table or initializing the machine, there will be special firmware to set it to default.
        • jmaister
          certified scrub
          • Aug 2010
          • 755
          color table does very little.
          when you need is in the kx driver. But even that's not great.
          its the Cyan isnt it?
          Idling colour developers are not healthy developers.
          • darry1322
            • Oct 2010
            • 817
            No I haven't.
            • simonsays
              • Aug 2013
              • 95
              well after having my rep come in there is a very big difference between them but you will only see it when you print big difference in the blue especially to which is toshiba the machine prints a totally different blue
              • serviceman678
                • Sep 2016
                • 19
                We have problems with blues so we use either konica minolta or toshiba color profiles it seems to resolve the problems with the blues. we use the profiles all the time big difference between kyocera and TO or KO you only can see the difference when you print. you will never see it when you copy
                • serviceman678
                  • Sep 2016
                  • 19
                  does anyone know what this reputation feature is located and how do you rate someone
                  • darry1322
                    • Oct 2010
                    • 817
                    You can also use the color reproduction dropdown in the imaging tab in printer preferences to select different types ( publications vs line art vs text + image, etc ... ). I've seen that work to match certain shades in a document without throwing everything else off.
                    • serviceman678
                      • Sep 2016
                      • 19
                      didn't know that i will try that for sure we have a lot of issues with companies logo's matching. you know customers want it to match exactly. Sometimes it can be very annoying
                      • dikyo
                        • Apr 2011
                        • 45
                        Hi,
                        Today i visited a customer who has a Taskalfa 306ci and a Taskalfa356ci.
                        On the 356ci i selected the colourtable FJ in U485.The customer was very satisfied with the result.(The color blue now is really blue and not green/blue)
                        On the 306 ci there is no U485 where you can choose the different tables.
                        These colourtables has to be installed by an USB-stick ,but are not avaiable yet. (I asked our support department).
                        Does anyone know how where i can get the colourtables for the TASKalfa 306ci?
