FS 1035 dead
  • Raymann
    • Apr 2015
    • 73
    FS 1035 dead
    Just got this machine I know nothing except the fuser ohms out good but there is no hint of life. Any other experience with this machine going dead? Thanks Ray
    • 23010
    Re: FS 1035 dead
    How about the output voltages on the power supply? =^..^=
    • tech28
      • Jun 2013
      • 434
      Re: FS 1035 dead
      Left side, remove cover, will see connectors to power supply, there is 1 connector that comes loose, that one goes under machine to main board make sure things are plugged in correctly. Even if no work has been done by the power supply area, that one plug barely is on and can come loose enough to give you a dead machine.
      • subaro
        • Oct 2010
        • 1274
        Re: FS 1035 dead
        In the machines i worked on with this problem, it was either the low voltage power supply or the engine-mainboard combo.
        • Raymann
          • Apr 2015
          • 73
          Re: FS 1035 dead
          well I have 17 volts where the 24 volt fan plugs in to..
