Ta2552ci. Etc
  • JSC
    Gimp
    • Dec 2006
    • 618
    Ta2552ci. Etc
    Anyone seen much of the new range machines. Got guys booked on the course, but not seen any yet.
    The gene pool could use a little chlorine.
  • Tonerkiller
    • Oct 2012
    • 669
    Re: Ta2552ci. Etc
    I went through the training and we have quite a few machines in the field. The machine looks
    easy to work on, has very nice features, and the ones we have in the field have not had any problems.
      Re: Ta2552ci. Etc
      Not seen any yet but the parts list goes from the 2552 to 6052 colour and also 4001i to 6001i with all accessories in one manual.
      Really good idea.
      • wragsdale
        • Jul 2014
        • 188
        Re: Ta2552ci. Etc
        Went to the course and with what little we got to see of them they look like a solid lineup. My favorite change has got to be the ITB/drum removal procedure, back panel screw reduction, or the cassette dampeners.
        I can't wait to get some out in the field, especially if they're replacing Saturns.
        • subaro
          • Oct 2010
          • 1274
          Re: Ta2552ci. Etc
          Exactly as above. Went to the course, but only got to see the low speed model, which they said the high speed platform is based on too. I was impressed by how easily it is to remove any part on the machine. The thing i really liked was the cassette dampers, where you cannot slam the drawers. you can remove the drum or dev individually without removing the transfer belt. Also the frame size has been reduced from the previous bulky TA, and they said it is stronger.
          AN EXAMPLE OF THE EASE OF REPLACING PARTS.
          4-183
          (5-2)Detaching and reattaching the engine PWB (High-end model)
          Procedures
          1. Remove one screw (a)(M3x8) and slide
          the rear top cover (b) in the direction of
          the arrow.
          2. Disconnect all the connectors from the
          engine PWB (b).
          3. Remove eight screws (a)(M3x8) and
          remove the engine PWB (b).
          4. Check or replace the engine PWB (b),
          and then reattach the parts in the original
          position.
