Kyocera 4500i Displays customer name on boot up
  • A\ztech
    • Feb 2011
    • 57
    Hi Guys just picked up this machine and I noticed it displays the old customers name on power up right after the welcome screen. instead of saying Kyocera it displays customer name then it goes to read and shows the normal display, also coming out of sleep mode it shows customer name. no big deal but I would like to get it back to normal before I deliver the machine to the new customer. I have tried everything reset memory and HHD installed Firmware with no luck. Any Ideas. Thanks in advance
    • 23010
    Re: Kyocera 4500i Displays customer name on boot up
    It's called a Splash Screen. And you can make it anything you want. Use service mode U224 to revert back to the Kyocera default.:
    http://www.copytechnet.com/forums/ky...me-screen.html =^..^=
    • A\ztech
      • Feb 2011
      • 57
      Thank You black cat that was it, you da man!
