default exit tray ajustment
  • COPYDOCAZ
    • Mar 2015
    • 110
    [Misc] default exit tray ajustment
    KM 2550 OLDIE........ Replaced the finisher exit tray for customer set the default exit tray for "FINISHER" but the paper comes out in the regular output bin inside. Curious... guess i should have checked if the staple functions worked but it sees the finisher for sure.
    • 22997
    Re: default exit tray ajustment
    If there is an error stored for the finisher, the finisher will be isolated, regardless of what settings you select. I think I would start with a U906 partial reset. =^..^=
