Kyocera TASKalfa 4551ci - calibration
  • kuby
    • Oct 2007
    • 1411
    Have a customer that has a Kyocera 4551ci that the copies are a bit light and she says the colors are off. Tried to do a Color Calibration on the machine but when you get to the point where you put the Calibration Page back on the glass and press continue it comes back with 'Measurement Page is not detected". And will not calibrate. Tried it from the PC on directly from the copier and get the same thing. Anyone had this problem. HELP
  • Luther
    • May 2006
    • 682
    Re: Kyocera TASKalfa 4551ci - calibration
    If your doing u410 that should only be done with a new drum, you can try auto calibrate in user tools, or change the color profile in u485 assuming all the consumables are still good, kyocera has a tendancy to print pale colors, i would try changing the color profiles,ko-konica to-toshiba,ca-canon we have been setting them all up using the toshiba profile but in the end its up to the customer, then set the color profile under the image tab on the driver to custom tables...hope this helps
    • Tonerkiller
      • Oct 2012
      • 669
      First how does the color belt look? Clean the machine, optics, charge rollers, laser glass, ect. Fix the copy issues before you do the toner curve adj.
      • nikolai.aleksie
        • Feb 2016
        • 177
        There is a service manual on this page as PDF format, hope it helps.
        DepositFiles provides you with a legitimate technical solution, which enables you to upload, store, access and download text, software, scripts, images, sounds, videos, animations and any other materials in form of one or several electronic files.
        Click "Regular Download" button, close Pop-Up, wait 60 sec..., click Reveal, close Pop-Up, enter Answer, click continue, click Download file
          • 23010
          Yes, if the image quality is bad enough it will not do a successful toner curve adjustment. Let's see the U089 Sample Set? =^..^=
          • copier parts n.ireland
            • Nov 2016
            • 41
            ive not had page not detected but plenty of cannot perform calibration,i found if it is nothing to do with pale colours,the usual back cursor guide on cassette is broken or needs adjusted,paper just moving about.worth a try good luck
