3550ci Fuser Pressure Grinding noise
  • buzz
    • Aug 2013
    • 288
    There is a loud grinding noise for a fraction of a second coming from the fuser area during a copy cycle.
    There are no error codes, and the copies/prints are fine. Super annoying to the customer of course of it being so loud.
    I did a motor output test and it seems like the noise is from the Pressure Motor.
    Anyone had this before? I have a 5550ci fuser and may try to swap parts.
    Any feedback would be great.
    thanks
    • 23006
    Re: 3550ci Fuser Pressure Grinding noise
    I have heard the fuser pressure motor make that noise, before it fails. =^..^=
    • copier parts n.ireland
      • Nov 2016
      • 41
      only loud grinding noises so far out of this model is side door press release motors,a few teeth broken off once a small gear on the 8300 1930 3005ci series fuser but not causing loud noise.let me know how you get on.
      • qbert69
        • Mar 2013
        • 1152
        ...that's why you KEEP your fusers that have reached yield and replaced!...swap out the motor/gear set from a known good unit and carry on!
        REACH FOR THE STARS!!!
        Konica Minolta Planetariums!
