Kyocera 5500i jams with a z fold code 4003 or 4004
  • Techman1000
    • Dec 2010
    • 44
    I have tried everything I can thank of still has the problem, sometimes you can one copy ok but more than one this happens Reg. sensor checks ok , new feed rollers, new transfer belt, I need some help if anyone else has seen this before. The copier has 2,700,000 copies on it!
    • 22999
    Re: Kyocera 5500i jams with a z fold code 4003 or 4004
    Have you tried changing the loop adjustment? =^..^=
    • Techman1000
      • Dec 2010
      • 44
      I haven' tried the loop adjustment, but I can't see how that would have changed, I'm the only Tech that has worked on this machine for 4 years, by the way this copier is 90 miles from our shop. I'm beginning to thank a previous post about 3050ci z fold jams with the same jam codes, large white gear worn on the shaft I believe he said drives the transfer belt. I usually don't mess with adjustments on a known copier that's been working for several years., but I will try the loop adjustment, I don't have anything to lose by trying it.
      • Geo
        • 662
        Hi..
        Replace the clutches (reg relay)... they're poorly made and are prone to run on.... and If I remember correctly a bulletin was issued with a brake mod for the reg roller assy . This mod are 2 friction pads that presses on the shaft to provide extra drag in order to prevent run on (clutch not immediately disengaging). Also replace your flags.
        Have fun
        • Techman1000
          • Dec 2010
          • 44
          Well, here's what the problem was, Kyocera calls it MPT assy. the manual calls it the paper conveying unit 2, part #302K994012. I would advise anyone with this problem to replace the whole unit given that it doesn't cost much! This is a real bear to replace given that the manual does not give any idea how to take this part out. I spent 3 trips & about 15 hours on this, so after installing the new one copier works fine, but I just had to take the old one apart 1st clutch was full of rust & shaft worn badly, 2nd the main problem two white rollers on the left hand side were popped out because the bracket holding the shaft in place was broken! I'm going to try Pulley unit.jpgConveying unit2.2.jpg!Conveying unit2.1.jpg
