Grey boxes when printing.
  • The_Murph
    • 96
    Hi all,
    I have a Kyocera 300i, when printing docs tat have been scanned and emailed from a particular agency, grey boxes are printed around all printed areas (see picture). I believe this to be something occurring during the scanning process, such as OCR or the like. Other agencies scans come out clear, as do internally generated prints. Any thoughts?
    If you phrase your inquiry properly, you will get the answers you seek...
    Good Luck ... You'll need it! HAHAHA!
    ~Big Dan~
  • NeoMatrix
    Senior Tech.
    • 3513
    Re: Grey boxes when printing.
    You may like to try the following thread, it could be relevant :
    "wwww.copytechnet.com\forums\sharp112699-bands-prints.html#post5367
    http://www.copytechnet.com/forums/sh...tml#post536765
    or
    HTH
      • 23008
      #1) Yes you are probably right about the effect happening in the scan process. Here is another example, initially blamed on the Kip wide format printer, but caused by a Toshiba eS4520C scanner:
      #2) Your image is too small to examine. =^..^=
