Wide Format Copier makes stripes (Point Source Ci 8020)
  • kyogenius
    replied
    Re: Wide Format Copier makes stripes (Point Source Ci 8020)
    remove your cleaning unit and clean the fibre optics.its your fibre thats blocked by toner .hope this will sort this problem.
  • plotten_225
    Guest replied
    I tried to open the copier, but I'm not a mechanic.
    I thought about the developer as well
    Any tips how to solve the problem? How to get to the laser to clean it?
    THANKS A LOT!
  • habik
    replied
    I think during transport there is either debree on laser / LED array (haven't worked on this machine.) And is not exposing to drum.
    Or the develper is not spread properly.
    Byting on bits.
  • plotten_225
    started a topic Wide Format Copier makes stripes (Point Source Ci 8020)
    Hello,
    thanks for helping out! I'm from Germany so please excuse my english.
    I have a Kyocera Mita Pointsource Xi820 wich "prints" white stripes.
    I don't think it is the scanner which is broken because it doesn't matter whether you scan a A4 and print it in A0 or Scan A0 and print it to A0. Its always the same white stripes in the same place (see pictures).
    I already put to cans of Toner/Color in it. It came here by car, the first 10-15 copies were all right.
    Does anyone has an idea?
