TA 3550ci image section repeat 6x or 7x
  • magtech
    • Jun 2011
    • 15
    Hi every one
    I have a Taskalfa 3550ci who when you copy from the glass, a section from the image repeat 6 or 7 times on the page (see attachment)
    The problem is intermittent
    I Updated the Firmware and replace the HDD
    Did someone ever see this problem ?
    thanks for you help
  • Geo
    • 662
    Re: TA 3550ci image section repeat 6x or 7x
    Your example was not very clear...However, did you check/clean all the charge rollers? Also given that image is repeating, measure the distance between the marks and check the repetitive defect chart in the SM..
    • darry1322
      • Oct 2010
      • 817
      Look at them again. It's not repeating a mark, it's repeating whole image sections again. It looks like some serious data processing issues.
        • 22941
        I had a Toshiba e Studio 306 do this ONCE. I have the samples. AFAIK it never happened again.
