CS 3050
  • Scottb
    • Apr 2013
    • 306
    CS 3050
    Hello all I have a oldie, and has been a goodie until lately. When copying from the DP the original size detection is off. It will read letter as ledger, and letter r as legal....only about half the time. I decided, that since we had a brand new DP still in the box that was about to go to the scrapyard, that I would just swap and be done....Ah if only life worked that way...the problem has returned. Has anyone ever seen this before....only guess that I have at the moment is maybe the florescent lighting is causing the sensor to have fits with its sanity.
    • 23008
    Re: CS 3050
    I found this comical entry in the database:
    Selects legal or ledger paper size when using the document processor. "Load Paper in MP tray." A 4" x 6" note has been taped over the original length sensor. Remove any obstructions to the original length sensor.
    Perhaps you do have room light upsetting the original length sensor. It is reflective. Can you turn off the room lights (even briefly) as an experiment? It would not be the first time that I wheeled a machine across the room for this reason.
    • Scottb
      • Apr 2013
      • 306
      Re: CS 3050
      Thanks Blackcat, Yes that was a comical entry, I haven't checked the lighting, as my prefrontal cortex was otherwise preoccupied with an false jamming issue with a DP772. I will run back by there today and check. On a side note I have had trouble lately opening the resolved cases on KDA Connect have you had this problem or is it just my new laptop causing me more grief.
        • 23008
        Re: CS 3050
        I haven't had any issues with that. =^..^=
        • Santander
          • May 2009
          • 768
          Re: CS 3050
          It is probably the lighting triggering the optical sensor on the original tray, we have had a number of these and moving the unit only few inches resolves it. As for opening resolved cases, we have run into this on several machines. Apparently Astea [the service database host] does not keep up with MS browser/system updates which is causing problems. We had one laptop running Win7 and IE10 that was working fine and suddenly could not open any of the resolved tickets. Another laptop running Win7 with IE 11 cannot even open the Astea website, it throws object errors for displaying the menu, etc. We contacted KDS tech support to resolve and NO JOY! It is frustrating not to be able to keep your system and browser updated without losing connectivity to the service database.
          • eddie110171
            • May 2012
            • 133
            Re: CS 3050
            We had several of these units where we had to replace the size detection board, Kyocera used a light dielectric grease instead of what they used previously. The new boards even come with the old style grease. For us it seems to happen at customer that still use leger and more the DP cursors all day long.
            • Tonerkiller
              • Oct 2012
              • 668
              Re: CS 3050
              It is the florescent lighting. By moving the machine a little will resolve it sometimes.
              • Scottb
                • Apr 2013
                • 306
                Re: CS 3050
                Yes it is florescent lighting, and if cleaning crew must have moved it a little because it operated properly the last time I went to test that theory.
