Kyocera 8000i with C2610 error code
  • dlandry
    • Sep 2015
    • 4
    [Error Code] Kyocera 8000i with C2610 error code
    The copier will come to ready and when attempting to feed paper from either deck 3 or 4 it sounds like a motor runs intermittently several times before stopping and going into error C2610. No paper has been fed from either deck when it happens.
    • 22927
    Re: Kyocera 8000i with C2610 error code
    Each time it's been the PF PWB. I've also changed the motor, just in case it was overloading the driver board. =^..^=
    • AlbertK
      • Jul 2014
      • 90
      Hi. I had the same problem on same model and it was a broken gear in the gearbox of the feed unit for trays 3 and 4.
      The product may be brilliant and the salesperson proficient, but if the technician isn’t efficient, then the story will end there.
      • dlandry
        • Sep 2015
        • 4
        Thanks for the fixes guys. It ended up being a broken gear as Albert stated. TI help anyone else who comes across this thread the part number is 303NF94040 and it is Parts drive unit SP.
