Memory Stick Question
  • copiman
    • Sep 2011
    • 861
    I need to replace the 2G memory stick on the main bd of 250ci. Has anyone done this before and if so how close to specs of the memory do you have to be? Kyocera wants $150.00 for their stick. Can't see paying that. I have a bunch of sticks at the house I will look at tonight that may work but thought I would ask.
    • 23008
    Re: Memory Stick Question
    240-pin DIMM, 2GB, 667MHz, PC2-5300U, unbuffered, non-ECC,CL5 ( 5 CAS Latency), 1.8v.
