CS 3500 with an F000 error code
  • Scottb
    • Apr 2013
    • 303
    Hello All,
    So I have checked/reseated the YC3 on the main, and YC46 on the reader. Swapped the cable from yc3 to yc46-same issue, swapped the Main pcb- same issue, and finally swapped the reader pcb...so now i am at a loss any other ideas would be appreciated.
    Also the donor machine comes to ready after its original boards were reinstalled and powered up, so they were and still are good.
    • 22932
    Re: CS 3500 with an F000 error code
    How about the operation panel, and the CODE DIMM? =^..^=
    • Scottb
      • Apr 2013
      • 303
      Ahhahaha, no it appears, that I was looking at the wrong code, thanks for the catch....I will keep you informed if the problem persists.
