Kyocera 4500i DP 770
  • tech28
    • Jun 2013
    • 434
    Can you swap out a 770 with another 770 from a different 4500i?
    • 23008
    Re: Kyocera 4500i DP 770
    Sure. Just update the firmware so that it's all at compatible levels. =^..^=
    • tech28
      • Jun 2013
      • 434
      Thank You, had a 9070 error, says machine Document feeder not working, Communication error between DP and SHD, nothing in service manual. Dont have parts manual for DP's. Know where the DPSHD is?
        • 23008
        The DP770 does not have an DPSHD. The DP771 does have a DPSHD board. It's the shading board for the CIS for the backside image.
        I suspect one is a DP770 and one is a DP771.
        • tech28
          • Jun 2013
          • 434
          Yeah, says communication error between DP and SHD, suspect pwb on DP went south. Blackcat, have a spare parts manual for the DP'S?
