When using duplex, copier jams and displays jam in bridge unit , the wierd part is copier is sending a second sheet also, when not selected and only when duplex is used. Tried all cassettes all paper sizes. When i swapped rt side transport unit it worked, what would cause the copier to send extra sheet. Thanks for replys
CS 8000I DUPLEX JAM
Re: CS 8000I DUPLEX JAM
jam code? =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
If the machine thinks that the first sheet did not feed, it will try to feed it again.Comment
