KM3035
  • tcypy1961
    • 773
    KM3035
    Is the solenoid the most common problem with the switch back ass'y??? The one in the copier had the paper stopping before exiting into finisher. The ass'y I swapped it with was periodically causing paper to stall. Problem only happens when either duplexing or paper exiting into finisher. Thanks!!!
    • 23008
    Re: KM3035
    What jam code?
    This is a lot more common:
    CS5050 exit guide.JPG =^..^=
    • copydocinc
      • Mar 2015
      • 263
      Re: KM3035
      On the back side of the switchback assy there is a gear that has a one way bearing that starts to slip when it gets old.
      You either need to replace that one way gear and or clean and roughen up the shaft where it rides on the shaft.
      YOu might also get away with a good cleaning of that one way bearing, with alcohol, but don't forget the shaft roughening part. (lightly use a file so its not so smooth)
      • Tonerkiller
        • Oct 2012
        • 668
        Re: KM3035
        What jam code?
        This is a lot more common: .
        [ATTACH=CONFIG]35376[/ATTACH] =^..^=
        I like the screw trick.
          • 23008
          Re: KM3035
          It's a scanner lock shoulder screw/setup screw from a Falcon III. It's ironic that they were the perfect size to re-purpose. =^..^=
          • Geo
            • 662
            Re: KM3035
            So what field service modification number is this :-)
              • 23008
              Re: KM3035
              page 6 record 252 on the database. That's about as close as I can get to a bulletin number. =^..^=
              • jper34
                • Sep 2011
                • 225
                Re: KM3035
                i always thought the 1way bearing,but after time,I just replaced the unit,as going back and forth to customers,I was losing money..
                • daveh12
                  • Jul 2012
                  • 157
                  Re: KM3035
                  What jam code?
                  So simple. These used to drive me mad.
