5052ci false waste toner full messages
Re: 5052ci false waste toner full messages
under usage machine is still left on turning
unlevel waste path.
parts past PM cycle
environment
customers not shaking toner properly
tech messed with bias setting so it wastes toner
poor design of waste system...Comment
The below are the best probably causes. Im working okay pin pointing where the grinding sound starts from. I will find out
unlevel waste path.
poor design of waste systemComment
1st .. is MACHINE level?
2nd .. grinding can be due to FULL waste lines 1st.. then over time.. build up.. packs toner in tube.. THEN the failure.. vac waste lines from each direction ... clean drums ( if toner recycle section ) ITB *same*
these can be PIA and dirty - time gobbling jobs.. but doing it RIGHT VS Quick ALWAYS pays outComment
