5052ci false waste toner full messages
  • nathicana
    • Aug 2008
    • 335
    We have multiple 5052ci type machines giving false waste toner messages. Called Kyocera and followed the u155 calibration procedure. Followed QA bulletin about reinstalling packing material on waste toner area when transporting machines.
    Is anybody having this problem or finding a solution? I suspect this affects all of the current machines with this type of rotating waste container such as 4002i-6002i, 2552ci, 3552ci, 4052ci-6052ci.
  • 20gaugeO/U
    • 557
    Re: 5052ci false waste toner full messages
    We were emailed the bulletin by our tech rep the day after an install of multiple machines. A couple of them did the false waste toner message a day or so later, a couple didn't. Did the U155 and left them a spare waste toner just in case and haven't heard back. Now we just remove the waste toner before transport. But we'll see if that's the fix (or reinstalling the packing material like Kyo recommends).
    • nathicana
      • Aug 2008
      • 335
      Thanks for the reply. If the waste containers need to be out of the machine during transport then they shouldn't be installed when Kyocera ships the machine to us.
      • bronco31
        • Aug 2009
        • 174
        going out on a serv call now.. random false toner waste full message.. 5052ci just placed in a super important account!
        • nathicana
          • Aug 2008
          • 335
          Did you discover a solution? Thanks
          • Rpizzle
            • Mar 2014
            • 47
            any news on this, just put a large fleet of these out.
            • bronco31
              • Aug 2009
              • 174
              I did the U155 Calibration and haven't heard back from the client!
              • blsquires
                • Nov 2008
                • 342
                just a point .we had a customer who was told save your empty black toner bottles and use them for waste bottles.good idea BUT the customer was replacing the waste bottle before the machine told them to .
                and they do mostly color copies .this means the black toner isnt used so much so now we have to supply them with a spare waste toner bottle on a regular basis.
                • bronco31
                  • Aug 2009
                  • 174
                  im not grasping this..but its early and i need coffee.. customer is " replacing the waste bottle before the machine told them to " ? why would they do that?
                  have a great day all you hard working and tired techs!
                  • tmaged
                    Owner/Service Manager
                    • Oct 2008
                    • 1902
                    In the US market, the default is for the doors to not open until the toner is empty. I would think this would be the same for everyone, but I could be wrong.
                    Hope that helps !
                    -Tony
                    www.dtios.com
                    Become a fan on Facebook
                    • Mhodges
                      Hi All
                      We had this problem loads when we first sent these machines into the field, we have found the best way is to remove the waste toner bottle before transporting the copier. Since doing this we have not had any issues at all.
                      • Drumluck
                        • Oct 2017
                        • 5
                        I had the same problem after recently moving machine, performed Sim U155 and everything has been great, no further problems
                        • "K"
                          There was a Firmware release in Late October, the 25th I believe, that fixes this issue. Basically there are too many sensors for that toner container and this firmware disables the one that causes the false readings.
                          Hope this helps.
                          • Alexkyocera
                            • Jul 2015
                            • 82
                            What if the issue reoccur??? Anyone found the root cause of this. These machines are making loud grinding noise, we need to come together and find the root cause.
                              full messages and grinding from that area .. usually means the augers aren't moving properly . or something is binding/bound up.
