Copystar m2551 Image shift help
  • vsluggo
    • 23
    [Misc] Copystar m2551 Image shift help
    I have a customer who when making copies thru the feeder and copying from top tray number 1 has
    a shadow edge line down the edge of the page (1 MM from rear edge) Tray two is fine. the scanner glass is not the problem!!
    This is the same as a registration line usually at the bottom only its on the rear edge of copied page only ( and so minute its not very serious
    Can someone tell me what code I need to input in to perform a image shift on tray one?
    This model is new to us. see picture attached
  • Kyo fan
    • Dec 2013
    • 368
    Re: Copystar m2551 Image shift help
    That picture is just a thumbnail. Post another one if you can where it's clearly visible.
    • 20gaugeO/U
      • 555
      U034
