Opinions on the TA 3252ci series?
  • Athlontini
    • Jun 2012
    • 269
    First time training outside of the Ricoh brand, and I'm learning the 2552-6052ci series. Seems so far like a nice machine, easy maintenance, but is there anything the forum-going public should know about these boxes? I've heard about the waste toner bottles getting damaged when left inside the machines during transport. What are everyone's opinions?
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1888
    Re: Opinions on the TA 3252ci series?
    No problems so far. They just released a bulletin for noise in the ext section. That's the first one as far as I know.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • daveh12
      • Jul 2012
      • 157
      There's another bulletin to change the preset count for feed rollers in cassette 1 and 2 in M mode U250 from 150,000 to 300,000. So it's not looking for rollers prematurely. As for common problems with the range, time will tell.
      • DavePo
        • Jul 2008
        • 305
        Have had a magenta developer unit, a yellow developer unit and a black developer unit fail. The magenta happened at initial power up, a seal was pulled out of developer unit and into drum unit. The black unit failed at about a thousand copies and lost coverage on rear side. The Yellow unit the latch for the mag roller failed at setup and would not let mag roller engage the drum. The yellow and black units where from same machine. Like the box however.
        • Athlontini
          • Jun 2012
          • 269
          Yeah, I suppose they're too new to really tell. Well, I will also be learning the 7052ci, so if anyone has any useful advice on working on that box, it'd be welcome in this thread too.
          • The_Murph
            • 96
            I'm impressed so far, did the factory training and found it worth disassembling and discussing the way the waste system works (see http://www.copytechnet.com/forums/ky...new-boxes.html) otherwise I've seen a failed dv (y) caused by mag roller cam broken. I think its an incredible line at this point.
            If you phrase your inquiry properly, you will get the answers you seek...
            Good Luck ... You'll need it! HAHAHA!
            ~Big Dan~
