fuser error code reset for KM-1650
  • Navy
    Brown Shoe Sailor
    • Jul 2006
    • 47
    I know i'm missing something, how do I reset a fuser error code on a KM-1650 copier?
    NAVY - Never Again Volunteer Yourself
  • Project Warder
    Have you tried using 906 to reset the error code ?
    • 10871087
      • Jan 2005
      • 1062
      run sim 163 (I think thats the one, It says something about resetting a fuser fault)
      Good Luck
      • kyoceradude
        The Great Gazoo
        • Aug 2006
        • 442
        Good Luck
        You are correct. Sim 163 for fuser reset, as long as the fuser is good. If not the next code you will get is c6000, indicating open thermistor or bad lamp.
        My mission here on Earth is to help all you Dum-Dums!
        • just a tech
          • Jan 2007
          • 332
          enter sims by 1087, 1087.. run sim 163.. usually,if error comes up again, it'll be c6000 = no heat or c6020 = high heat.. thermistor is possible cause of both.. i've gotten c6000 before and have found them dirty sometimes and sometimes just not functioning well.. hope this helps...
