WHITE TOUCH PANEL
  • stephen miti
    • Jul 2025
    [Misc] WHITE TOUCH PANEL
    Touch screen on kyocera taskalfa 4551ci appears white when the machine is switched on. You cannot read any other message because the screen is just white. how can this problem be sorted out?
    You cannot read anything - if at there are error codes or faulty messages. The screen is not blank, but switches on to white colour and the only light seen on the control panel is the call for service symbol - the spanner. What can you do if you cannot read other instructions on the touch panel?
    Which part could lead to such a problem so that we try it and see if touch screen will come back to normal?
    • 23008
    Re: WHITE TOUCH PANEL
    What have you done so far? =^..^=
