I am curious if anyone has sourced the cassette feed rollers instead of the entire feed assembly (302K394480) for machines such as the FS-6525 and FS8520 . Thanks for your help.
FS-6525 Feed Rollers source instead of feed assembly
Re: FS-6525 Feed Rollers source instead of feed assembly
its the same rollers as the TA3551ci/3500i ... precision roller is good for searching for part numbers and compatibilities
302HN06080
302F906230
302F909171If you phrase your inquiry properly, you will get the answers you seek...
Good Luck ... You'll need it! HAHAHA!
~Big Dan~
