FS-6525 Feed Rollers source instead of feed assembly
  • DougMoney
    • Feb 2017
    • 70
    I am curious if anyone has sourced the cassette feed rollers instead of the entire feed assembly (302K394480) for machines such as the FS-6525 and FS8520 . Thanks for your help.
  • The_Murph
    • Mar 2016
    • 96
    Re: FS-6525 Feed Rollers source instead of feed assembly
    its the same rollers as the TA3551ci/3500i ... precision roller is good for searching for part numbers and compatibilities
    302HN06080
    302F906230
    302F909171
    If you phrase your inquiry properly, you will get the answers you seek...
    Good Luck ... You'll need it! HAHAHA!
    ~Big Dan~
    • DougMoney
      • Feb 2017
      • 70
      Thank You.
      • Practic
        • Oct 2014
        • 56
        Probably you can use these as well: 302BR06521, 302F906230, 302F906240. But you need to replace all rubbers from rollers.
        Sent from Ericsson DBH 1001.
        • DougMoney
          • Feb 2017
          • 70
          Thank You. I figured between these sets I should have most of them covered. Thanks again everyone.
