Kyocera fs6525mfp
  • rudysemira
    • Oct 2016
    • 108
    Kyocera fs6525mfp
    Hi i am new for kyocera reparing this machine i encounter problem for fuser unit i have cleaned the area for exit tray there are lots of sensor if i going to copy single side its fine but if double sided the paper was jam in the fuser unit i thought the fuser lower roller is the problem. Any suggestion before i replace it.? Thanks in advance.....
    • 22999
    Re: Kyocera fs6525mfp
    What jam code? =^..^=
    • rudysemira
      • Oct 2016
      • 108
      the jam code appeared on screen was jam 0508 from the area eject section going to to duplex, sometimes was stuck on fuser unit possible the fuser lower roller is having problem or the sensor from the middle of eject upper section assembly...
      • Santander
        • May 2009
        • 768
        A jam code of 0508 indicates that the paper is not reaching the registration sensor in the allotted time when in duplex. Since you say single sided copies are OK, I would suspect that the rollers in the switchback section have become glazed and are slipping causing the paper to not reach the registration sensor in time causing the code. I would not suspect the fuser unit as single sided copies do not cause a jam code and you do not get a code for the switchback sensor. Since the switchback sits right above the fuser, the "rubber" rollers are subjected to quite a bit of heat that can dry them out causing them to slip. Simply cleaning them [not with alcohol] in most cases will restore them. Hope this helps.
