Kyocera M2035dn Registation Varies
  • DougMoney
    • Feb 2017
    • 70
    I have a Kyocera M2035dn in a customers office that has given varying registration since new. It has about 1100 prints on it now and is about two months old. I had to adjust the lead edge slightly out of the box to get it right but it still will give 1-3 out of five prints 1/4-3/8 inch late. It doesn't matter if it is prints or copies and it doesn't seem to matter if it is single or multiple prints. It seems to feed fine without many jams (33 in 1100). I just can't seem to see what is causing it. I thought maybe a loose registration switch but it is in position and working. Any other thoughts? Thanks.
    One other thing, I can't confirm totally, but it appears that when it is late, it is consistent on the registration meaning when it is off, it is off by the same amount each time.
  • tmaged
    Owner/Service Manager
    • 1863
    Re: Kyocera M2035dn Registation Varies
    As with the 1128/1135, I'd check the mylars at the reg roller. Next is usually the drive unit.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • gdisc54
      • Feb 2012
      • 6
      I have seen the acoustic foam on the registration solenoid get sticky and cause varying registration remove it clean plate good put a piece of electrical tape in its place
      • Luther
        • May 2006
        • 682
        Make sure the spring for the roller in the paper tray is present...33 jams in 1100 copies seems to be a little high for that machine
        • campy
          • May 2012
          • 315
          I had several FS-1028 clutch pack be the problem, but mine were jamming after a few copies because the registration timing was so far off.
          • daveh12
            • Jul 2012
            • 157
            33 jams in a new machine especially with only 1100 prints is very high. What is the jam code/s?
            • DougMoney
              • Feb 2017
              • 70
              Is there an easy way to get to the mylars on this? The manual is not very good at all when it comes to this area. It appears that clutch is part of the drive pack? Thanks for your help.
              • buzz
                • Aug 2013
                • 288
                Remove side panels, bypass section and make loose the top plate in registration area (screw on each side under side covers).
                I am able to use the edge of my spring hook tool to scrape off both mylars being careful to not leave any adhesive behind. Each mylar is about a quarter inch by 1.5 inches. Its located beneath that registration plate. I've removed mylars from a few machines without bothering to replace them and they are working fine.
                This works for me but would like to hear more suggestions from others on this.
