Kyocera Ecosys M6535- No paper in tray
  • ChrisG
    • Oct 2013
    • 181
    Copier isn't recognizing that there's paper loaded in the tray. Paper sensor arm looks bent, possibly broke. Customer is 2 hours outside of area and billable. Has anyone torn into the sensor assembly for these? Other than an exploded parts diagram, have found very little as far as replacement procedure. Sensor assembly looks to sit in bottom frame of the machine but if anyone can shed some light on this, I'd much appreciate it.
    Chris
    TJL Copy
    • 23008
    Re: Kyocera Ecosys M6535- No paper in tray
    I've never had it out, but you'll get the best view of it with the consumables removed, and the MFP laying on it's back. There's a metal crosspiece that links together the two tray rails (4 or 6 screws to remove), then there it is. =^..^=
    • Santander
      • May 2009
      • 768
      Chris
      TJL Copy
      Most likely cause is the customer has knocked the rotational spring on the actuator off and it is not returning it to the proper position. Have seen this before.
