takalpha 650C fuer drive problemm
  • axyun
    • Aug 2007
    • 1323
    Very loud fuser drive noise. Repaired fuser and changed fuser drive gear 8H30-8 which is in direct engagement with fuser unit . Teeth were worn down. Ran machine and still noise but not nearly as bad. Fuser was free. Removed fuser and turned green handle while holding new drive gear. There is still a drive issue from fuser drive unit in rear of machine.
    Customer was upset that I had not diagnosed problem on fuser drive unit and chased me out. Did not get a chance to remove rear cover and open system case to access fuser drive unit. Does one or more of those gears get damaged along with the gear I changed.
    I am arranging with customer to go back and complete job and would like any assistance anyone has to offer regarding this problem. i think I am on right track but would like some input from someone with experience on this. Your help is appreciated very much. I have not been paid anything yet and already have an investment in parts and time.Frank
  • Tonerkiller
    • Oct 2012
    • 669
    Re: takalpha 650C fuer drive problemm
    I have felt your pain. When we had these machines this was a common problem. I would replace the gears that were worn and I would put some grease on the shafts to reduce the noise.
    • axyun
      • Aug 2007
      • 1323
      Tonerkiller, can you tell me which gear(s) generally will go on the fuser drive unit..frank
      • JR2ALTA
        • Feb 2010
        • 2033
        This machine a horribe, short-lived Frankenstein between Kyocera and Toshiba. I feel for ya, Frank.
        The problem you have now is that 1) the fuser drive isn't sold as a pack 2) the customer won't let you re-diagnose the machine
        Looks like you need to order all the gears. Do you have the manual? I can give the pertinent pages if needed.
        • Luther
          • May 2006
          • 682
          its actually a toshiba 6520c we replace the whole fuser drive unit because it was updated in the toshiba machine
            • 23010
            That's my recommendation, axyun. Install the eS6520C fuser drive pack. There are nearly a dozen gears, clutches, and bushings that wear. I could make you a list, sure ... but, until you get it disassembled you won't know which ones. I keep a rebuilt unit in the car for such purposes (and consequently know exactly which parts were installed right at the beginning), but I imagine that you don't see them often enough to justify that. Most of the Toshy guys just carry a new assembly.
            They tend to be noisy, but you know that. =^..^=
            • axyun
              • Aug 2007
              • 1323
              Thank you guys for the great input. The best course of action for me is to
              get the whole fuser drive assembly, especially due tom lack of experience
              on this machine.
              I see the part# is 6LJ08828000. If I am incorrect, please correct me.
              Now togged good prices seethes could be expensive,especially after
              repairs on fuser unit.
              I see in service manual that after removing rear cover I would need to
              remove systen board cover anodyne case after disconnecting a few connectors.
              This is all if the customer agreess to additional cost of fuser drive unit. Thanks again to all. Will keep you posted,Frank
                • 23010
                It's surprisingly easy to get to.
                There are 4 or 5 connectors that must be removed. With the covers off the cage box, and 4 or 5 more screws, you can swing the board assembly to the right out of your way. You'll have to remove the covers from the door side, the green knob and bracket, the fuser, maybe 6 screws, then the drive assembly comes out.
                If it were me, I'd keep the core, and make a list of the worn components. Especially watch the bushings. They'll oval out to the point of cutting into the side frames. Clean the parts that you want to keep in orange solvent and toothbrush. When you re-assemble use a slightly heavier oil, like 30 straight weight motor oil, since it gets warm near the fuser. No oil on the clutch please. Now you have a rebuilt assembly for the next occasion.
                • axyun
                  • Aug 2007
                  • 1323
                  Thank you David. Excellent useful info.
                  • qtech
                    • Jul 2009
                    • 41
                    Also....if entire assembly is required, purchase the Toshiba drive unit; it is less than half the cost of the Kyo drive.......
                    • axyun
                      • Aug 2007
                      • 1323
                      Thanks qtech. Gave customer quote and still waiting. Will call again tomorrow.Frank
                      • jmaister
                        certified scrub
                        • Aug 2010
                        • 755
                        Superlube is your friend. ABNORMALLY high load fuser drives need slick synthetic grease in them cogs.
                        Idling colour developers are not healthy developers.
                        • Ctl-Alt-Del
                          • Jul 2006
                          • 430
                          The Kyocera parts pricing for this model series was (almost) always higher than Toshiba pricing, I remember pricing out all the Feed, PM and TB1 items when the machine launched and with the exception of 1 or 2 items, Kyocera was significantly higher for everything.
