Network LED not coming on after the Move
  • sungminee
    • Jul 2025
    [Misc] Network LED not coming on after the Move
    We have a client who just moved.
    The problem is that their Network card is not working (no LED on).
    However, the line is working because when we are testing with computers it is working fine.
    Have anyone experience this issue? any solutions?
    I will wait for your reply.
    Thanks in advance.
    Calvin
  • aandy_py
    • Aug 2015
    • 15
    Re: Network LED not coming on after the Move
    Hi
    Who moved the machine? I have seen these connectors damaged as they are pulled away without disconnecting the network cable.
    • sungminee
      it wasn't damaged. we switched the board and still did that. also, when a laptop is connected to the copier 1 to 1, LED comes up and they communiate.
      thank you for your answer.
      • darry1322
        • Oct 2010
        • 817
        Try changing from auto detect network speed to whatever speed they are using.
        • driving lots of miles
          • Jun 2016
          • 398
          If the laptop will connect the problem is not in the copier but the line coming to the copier.
          • daveh12
            • Jul 2012
            • 157
            Is the cable a crossover or straight through? If connecting the laptop directly gets you green leds on copier you can forget about the problem being copier related.
