kyocera machine KM5050 ( Error message )
  • ahmed_dcc
    • Sep 2012
    • 36
    Hello everyone
    There was a problem with kyocera machine KM5050 and I updated the firmware of the machine and after updating this message appeared
    1- the optional font is not properly installed
    2- the report may not be correctly printed
    Then you change the firmware to another version and this message (no change)
    is there a solution
    Thanks to all
    • 23008
    Re: kyocera machine KM5050 ( Error message )
    What version did you load? Did you attempt a second time with the same firmware? In the USA it's version 2.45A.
    You may need to replace the CODE DIMM and load firmware again. =^..^=
